Iorad: Share Tutorials in Messenger in minutes!
#1
Hey :wave:,
Iorad is LIVE in the Intercom app store and ready to use with Intercom Messenger.
Iorad massively reduces the time spent creating solution articles and provides more time to directly assist customers through Messenger. iorad speeds this process -10X! In Intercom, pop into the App store & install iorad to start publishing tutorials straight to Messenger. Using the iorad extension, click through the steps in real time. iorad captures each step of a process as you go. Using iorad, you’ll have a fancy step by step tutorial available in your intercom messenger in just minutes.
While you’re at it, check out iorad on Product Hunt.
  • Sundeep @ iorad
