Messenger in another IFrame?
#1
Hi,
We’re implementing a Content-Security-Policy (CSP) for a SaaS. What’s your opinion of putting the entire Intercom component into an variable-size IFrame?
Then we can insert the IFrame into the site, set all user parameters in the IFrame and resize it when needed. That allows us to set a different CSP for the IFrame & the main app.
Are there any technical reasons against the Messenger in an IFrame (other than not being the official way)?
I’ve seen the recommendation for a CSP. But we’d really like to avoid ‘strict-dynamic’ at all cost, as well as a very lengthy host list.
Thank you!
#2
Hey @hawe :wave:
There’s no problem with putting the Messenger within an iframe, provided the iframe is big enough to fit the full Messenger when expanded :+1: It’s not officially supported, so if something does go wrong, then it’s out of our hands. Otherwise, go for it!
