Product Tour Resource Not Loading
Hello,
We have a product tour that has 2 steps. The first step is a simple ‘pointer’ over a WooCommerce product which works great. Clicking this leads the user to a product page where a ‘post’ should display but it doesn’t load. Using the ‘pointer’ option for both works fine, but the other 2 options fail.
Looking at the console, there aren’t any errors to report. The only difference I can see within the iFrames is that the first screen loads 10 JS files within the iFrame head but the second screen that displays a ‘post’, just loads 2 JS files: frame + vendor.
Has anyone experienced this before or know a way to fix the issue?
