Using Webhook with AWS lambda function
Hello,
I have set up a webhook on my test App which posts json data to a Request Bin, and that is working fine, but I want to send the same json data to an AWS lambda function, and that requires not only the url but also an AccessKey and SecretKey setting up. Can this be done in Intercom App?
Ged
Hey @GedW - you’d have to handle it your side somehow by taking the existing webhook payload which we send to your given URL, and you adding required fields to pass along to the AWS lambda function. You can’t edit the contents of the payloads we send you directly through Intercom :+1:
