Validation Request
#1
Isn’t it possible to validate the data we get from the user?
#2
Hi,
There is no default validation as such, it would need to be performed on your end. i.e. you can check the input returned and do any validation necessary. We do provide an error style text component if you want to return an error for these type of validation action and update the canvas.
Hope that helps.
