@intercom/intercom-react-native/ios/IntercomEventEmitter.m:2:9: 'Intercom/Intercom.h' file not found
Builds on bitrise are failing with either of the following errors alternatively :
@intercom/intercom-react-native/ios/IntercomAttributesBuilder.h:2:9: 'Intercom/Intercom.h' file not found
@intercom/intercom-react-native": "^3.0.4
"react-native": "0.71.10"
Podfile.lock
  - Intercom (12.4.3)
  - intercom-react-native (3.0.5):
    - Intercom (~> 12.4.3)
Best answer by David Srun
Seems like it solved by itself on our side today, maybe you should update your intercom to latest version.
  • 6 replies
  • July 3, 2023
We are having the same issue
@intercom/intercom-react-native": "^5.1.0"
Podfile.lock
  - Intercom (15.0.1)
  - intercom-react-native (5.1.1):
    - Intercom (~> 15.0.0)
the example app in the package repo also fails with the same error
intercom-react-native/ios/IntercomAttributesBuilder.h:2:9: fatal error: 'Intercom/Intercom.h' file not found
#import <Intercom/Intercom.h>
  • 6 replies
  • July 4, 2023
  • 512 replies
  • July 7, 2023
Hey @Ananthu Kanive Racheal from the support engineer team here👋
Yes, David is spot on here! We had an issue that has since been resolved. Can you try updating your SDK and see if the issue persists?
@Racheal can you please elaborate on what went wrong?
Not only were the CI builds failing and blocking production releases, but our developers were also blocked on debug builds! We had to remove intercom to proceed because we didn’t hear back from the intercom team for more than 12 hours.
What if it was a critical & time sensitive update? We deserve an explanation.
  • 6 replies
  • July 26, 2023
We also were on a production release build. This was critical and I cost me one day of dev to debug this, for nothing… Anathu is right.
