Autotag abandoned conversations
  • January 27, 2025
  • 13 views
Hi guys,
So we are on Alpha testing when Fin answered the question and customer becomes inactive and I can set up Fin to use a reusable workflow and do whatever I need including setting up a conversation tag.
But you don’t have the same way for the workflows, as customer also can become inactive while using a custom bot and there is no way I can send a CSAT survey or us a reusable workflow with follow ups. When the option of using a reusable workflow be available for custom bots?
Thanks in advance.
Best answer by Emilygav
Hey there ​@Rick A, Emily here from Support Engineering at Intercom πŸ‘‹πŸΌ
Currently, there is no direct option to trigger a reusable workflow when a customer becomes inactive while using a custom bot. The closest available feature is the "Customer has been unresponsive" workflow, which only triggers when there has been a teammate reply on the conversation, not when the AI or bot closes it. Sending a CSAT survey or using a reusable workflow with follow-ups when a customer becomes inactive is not directly supported unfortunately.
If you need more detailed information on setting up workflows, you can refer to the Workflows explained article.
However, I would be happy to put this through as a feature request to our team for further analysis!
Emilygav
  • 82 replies
  • January 31, 2025
