Hi,
Where is the settings for the resolution bot ? like wait time to start sending suggestion ?
Why the resolution bot don't answer and not triggered even if we set the exact questions and qualifiers ?
Thanks
Tamer
Hi,
Thanks
Tamer
Best answer by Titho
Hey Tamer, welcome to the community.
I am assuming you have set some resolution bots up and have trained them.
In terms of the common resources (you may of seen already);
https://www.intercom.com/help/en/articles/2409258-how-do-i-set-up-resolution-bot"alt="http://https://www.intercom.com/help/en/articles/2409258-how-do-i-set-up-resolution-bot"target="_blank">Setting up resobot
https://www.intercom.com/help/en/articles/2408827-train-resolution-bot-to-provide-more-resolutions"alt="http://https://www.intercom.com/help/en/articles/2408827-train-resolution-bot-to-provide-more-resolutions"target="_blank">Training the resobot
We have found to get reasonable coverage you need to add at least 15-20 variations of the question you want to cover + train the bot to match against real conversations in the customers experiences and language/words. See below taken from the Intercom article;
If you continue to find that the bot does not trigger, I would share the conversation URL and bot URL with Intercom support and have the investigate for you also to see if there is anything amis.
Hope that helps.
