Hy I am new here. Can I edit the article and change its url after posted it?
Best answer by Racheal
View originalHy I am new here. Can I edit the article and change its url after posted it?
View originalHey
Â
Definitely! The URL of an Article is based upon it’s title, so when you update the title the URL will change as well.Â
ok thanks
Â
Can we remove the article number after the article? For instance, I would like to remove the 182 in the following URL.
Â
http://help-center.test/myapp-26/en/articles/182-thanks-for-everything
Which is good short or long url? for example:Â https://dronesurveysworld.com/how-high-can-a-drone-fly/
