Importing hundreds of web pages into Help Center articles?
  • 26 October 2022
  • 63 views
We want to import hundreds of .htm URLs into their own respective Help Center Articles.
I see it is possible to import help documentation articles with Zendesk, but is it possible to automate an import of hundreds of .htm URLs into their own respective articles as we are aiming to do? Just looking for some guidance on how to begin this process, rather than copying and pasting each article over to Intercom manually.
Thank you.
icon
Best answer by Kevin Bendixen 27 October 2022, 09:07
Userlevel 3
Badge +5
I'm not completely sure, but you might be able to do this with the API
Hi, Is there still no way to do this ? Apart from copy paste ?
Using the API requires a dev…
@Sriya did you find a solution?
