Integration between Intercom and KakaoTalk? | Community
  • March 12, 2024
  • 205 views
Are there any 3rd party solutions available to integrate Intercom and KakaoTalk?
Hi @curiousperson !
I’m not seeing an integration in the Intercom App Store, but when I searched Google I did find a possible solution from Pipedream here
Other than that I’m not seeing a lot of leads. Intercom does have a public REST API and Webhooks that can be used for building your own integration if you have the Developer skills!
  • March 17, 2024
Hi @curiousperson !
