Hey @libor !Resolution Bot routes conversations based on the assignment rules you have set.
If you have the bot inbox enabled, assignment rules will apply after the bot interaction has ended.
If you don't have the bot inbox enabled, assignment rules will apply before the bot interaction starts.
It's important to note that even when Operator successfully closes a conversation, the conversation will still be assigned to the right team/teammate’s conversation list, but the conversation will show as closed.
This means that:
- If you have no assignment rules set up, the conversation will end up in your "Unassigned" Inbox if Resolution Bot is unable to answer the question.
- If Resolution Bot successfully answers the user's question, and the user clicks the "That helped 👍 "button, the conversation is automatically closed.
- If the user's question is answered and your customer doesn’t respond, the conversation will follow your assignment rules. If there is no response after three minutes, the conversation will automatically close, as the customer’s question was most likely answered.
You can find more on this here
If you feel that it was not properly assigned, I would suggest you to open a conversation with our support team from the Messenger in your workspace.
