For example, I want to create a cancellation flow and want to keep track of the reason why they are canceling.
Is there a way to keep track of responses that customers are selecting during a resolution bot?
Hey there @Red Glass 877 ! Oséas here from the Customer Support Specialist team 🕵️
You could use tags to keep track of the user's reply to each path. For example, if they select "Pricing" as a cancellation reason when the Resolution Bot displays the reply buttons, you can add an action such as "Tag user with pricing_reason" so you can keep track of their answer. Another option would be creating a custom user attribute such as "cancellation reason" and setting up a path in the Resolution Bot where the user will be able to fill it themselves.
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
