Possible to specify width for canvas inputs on Frame applications? | Community
Question
  • Nov 16, 2022 5:12 PM UTC
  • 156 views
Hello Intercom. 👋🏻
We're in the midst of finalizing a Frame app integration, and are down to final UI details. One thing we'd like to understand, is if we can configure the width of inputs in the modal that appears. By default, it seems they are constrained to just slightly over 50%, and it looks rough. Lots of wasted space; surely there's a way?
Here's what I mean (attached). Full horizontal real estate possible? 🙏🏼
Alex
  • Dec 20, 2022 6:18 PM UTC
Hey @alex l16​ Racheal from the support engineer team here👋
I've been doing a bit of testing on our frame style apps in the Inbox and inserted into the Messenger, and although it looks like the issue is fixed for our new Messenger, M5:
Screen Capture on 2022-12-20 at 12-15-54It looks like I'm still running into a funky scrollbar issue with the Next Gen Inbox:
Screen Capture on 2022-12-20 at 12-18-08If you'd like to, go ahead and write into support and we can get you added to the issue to keep you posted with updates!
