Hi guys, does anyone know if we have any addons for remote support? A company I work with had this question and at least I couldn't find it.
Page 1 / 1
For example Zoho Assist might be your best option, they have a Zoho Assist integration with Intercom
You’ll find a few other options in the app store that support co-browsing but not sure about Remote Support directly.
Wonderful Nathan, thank you very much, I'll look into it now!
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
