The user can see the article title, but when selected, the article screen goes blank. I have checked article and messenger settings to make sure everything is set up correctly. What am I missing?
Articles are not showing in Messenger.
Best answer by Kevin Bendixen
@meghan j Then you should contact Intercom support to see if they can help. It's not a general problem, because it's working in our messenger.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
