When using anchors you can't seem to be able to add just the anchor as a link "#example-example" without Intercom adding "https://" in front of it and rendering the anchor useless. Any way around this?
A workaround is to use the full URL but this means that for every link it sends visitors to a new window, which is not great.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
