Hi everyone, is there a way to back up the published Articles, download it & save them somewhere safe? 🙂
Best answer by Milan
View originalHi everyone, is there a way to back up the published Articles, download it & save them somewhere safe? 🙂
View originalHello @wendy b​ - there's no such feature, no export (like there is import feature with Zendesk).
Â
So what are the options:
Â
So not a lot of options here
@wendy b​ Not sure how much this would help you, but using the Intercom API you could export all articles as a JSON file. @daniel f11​ shared a script where this is done. Check his post.
Can someone on intercom side confirm if articles are secure and backed up on their end (we put a lot of time into our articles!)
