When I import an article from Notion to Intercom, I use the import option of Intercom. It does a nice job, but the imported article is “internal”. How do I change it to “public”?
Changing internal article to public
Best answer by Emilygav
Hey there
There is currently no way to convert an Internal article to a Public one. You would have to create a public article with the information from the Internal article.
Hope this helps 💪🏼
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
