Forum Like Capabilities | Community
  • February 5, 2021
  • 9 replies
  • 655 views
It would be nice to have forum like capabilities. (Like zendesk.com/gather)
Hello @joshua d​ , I don't think that building community product in the nearest plans of Intercom, cause even Intercom using Salesforce community.
That's just my opinion, how about using some famous community portals like:
  1. Discourse - It's free and used by Cloudflare, Amazon and etc...
  2. Circle - New start-up with nice design
I hope this will be helpful
  • February 5, 2021
Yeah thats unfortunate. It would be great for the integration with the intercom platform. I didn't really like Discourse (the look is a bit old fashioned for me) - circle is cool, might have to look into that. I wonder if they have an intercom integration...
  • February 5, 2021
@joshua d​ , Discourse is open-source, so you can fully customize it.
What did you mean by integrating Circle with Intercom? Displaying Intercom messenger?
Yes, it's possible - https://community.circle.so/c/product-updates/extend-integrate-and-customize-with-head-code-snippets/p>
Sorry, I meant that I want ONLY "users" of my app to be able to see and use it (like how intercom can only allow users to view the KB)
  • February 5, 2021
@joshua d​ , In this case, you should use SSO, which will allow your app users to log in to Circle without opening an external account (Like you are doing it with Intercom Community).
If you check Enterprise plan offering SSO - https://circle.so/pricing
They also have some restriction options, anyway best way here to reach directly to Circle support or their community:
https://community.circle.so//p>
Hope my answer was helpful 🦄
  • February 5, 2021
Hey @joshua d​! I'd love to see a point in the future where we build our own solution in this space. Being perfectly honest, I'd love to use this community as the perfect case study for our product team as to exactly why we should build this kind of thing!
  • September 24, 2021
Hey @joshua d​ I'm wondering 8 months later how you solved that problem. I'm going to look at circle and discourse. I've also found insided.com. We're running a consumer software as a service business and have already found a number of superfans who now want to be chatting with each other. I'd love to learn from your experience.
  • February 17, 2024
Has anyone successfully integrated their Intercom knowledge base with Discourse?
Oliviervdh
  • January 26, 2026
Hi ​@Madelyne W ​@User667 ​@IntercomCustomer, we have built this feature at Turf. Its an Intercom partner integration that allows you to add community forums directly inside your Intercom messenger for this exact use case and essentially allows you to build a full fledged community directly in the Intercom messenger and can also sync your knowledge base with your community environment.
Not sure if this fits your use case but here is the link to it in the Intercom app marketplace if it helps: https://www.intercom.com/app-store/?app_package_code=access-community&search=turf
Would love to get your feedback (and thoughts on possible improvements)!!! We just released it as an Intercom partner 😁
