Hey @user892, can you tell me a little bit more about how you've set up this rule? How are you sharing the articles? Is it through a chat message using the Article Inserter app?
Our web apps just display the whole Help Center when users click Help. Then they self help.
Hello @user892 , I will jump into this conversation. If you are planning to restrict articles based on user products, you should send Intercom data attributes.
Example:
1) Creating Data Attibutes let's say - Product
2) Send Intercom data - Product = Product1 or Product = Product2
3) Restrict articles based on the data attribute
The Help Center URL will be one - Like Help.example.com.
When a user makes a log-in to your app and redirects to the help center, they will see appropriate articles.
Let me know if you have any further questions or need some video instruction on this case. I will be more than happy to provide all information.
Looking forward. 🦄
thanks for the input. custom attributes require engineering cycles, which i was hoping to avoid. seems we will have to bite the bullet.
@user892 , Are you currently tracking logged-in visitors in Intercom? How about using tags instead of data attributes?
not yet. help center is the primary use case right now. i inherited a help center for a legacy product. we have a new product under development.
