Can I download /export the performance of our articles? Views, etc.
How can I export my Article statistics?
Best answer by Racheal
Hey @jess sโ Racheal from the Support Engineer team here๐๐ผ
You can export articles through the Articles API, full details on how to do this can be found in our Dev Docs. In the Article Model you will find a statistics object this includes the Articles views and reactions:
I hope this helps!
Join the Intercom Community ๐
Login to the community
Log in with SSOor
