How do I connect Route53 cname to help center and articles using custom domains?
Best answer by Anonymous
Hey there,
To use Route53 you'll need to setup a CNAME that points to intercom.help, and add the domain in question as a custom domain in Intercom:
Check out https://devcenter.heroku.com/articles/route-53#cname-recordsas a guide to setting up CNAMEs using the AWS Console.
Let me know if it works out for you 😀
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
