How do I get around the LinkedIn auth wall when linking from the Help Center? | Community
  • February 15, 2022
  • 1416 views
LinkedIn link in the Help Center footer hits a LinkedIn auth wall. Any tips on how to get around that?
Best answer by Lisa B11
Hey @user892​ 👋
Would you mind sending us a message through the Messenger including the full URL you are adding to the LinkedIn button so we can investigate this for you 🙌
  • February 17, 2022
Hey @user892​ 👋
  • February 17, 2022
done
