How do i turn on auto correct on intercome | Community
  • May 11, 2022
  • 192 views
Best answer by Adam W
As I understand it, it'd be based on your OS and/or Browser you're using to access it. In the end I ponied up to use Grammarly because my typing is...sub-optimal! However, that doesn't necessarily autocorrect as I type! The best solution to that I've found is:
MacOS: System Preferences > Keyboard > Text
Windows: Beeftext (weird name, awesome app)
  • Innovator
  • May 16, 2022
