Hi everyone,
We're currently using Elevio where our knowledge base is hoted (help.subbly.co). We'd like to migrate the existing KB over to Intercom for a more streamlined solution when handling regular day to day support.
Q's:
- What is the painless way of transferring the entire KB over to Intercom? Is there a way of importing the articles in the form of CSV or any other method? I tried the scraping tool in the past and it worked on only a handful of articles...
- Does Intercom provides the stats about most common searches and, more specifically, empty searches within given time period? Is that information readily available (like suggestions which articles to add?).
- Are we able to add keywords to the Intercom articles?
- I read somewhere that images need to be hosted elsewhere, is there no way to simply upload pictures/screenshots directly to the article when writing one?
- Does related articles bot (suggestions) come with a regular Articles app with Intercom? I'm specifically looking into possibility of adding suggested/related articles to each article so customers can continue reading through the rest of the KB?
- What are the possibilities of structuring the KB at all on Intercom? We're specifically looking to build two different branches (KB vs. Help Center). Is this possible to build 2 completely separate pages and to keep them apart?
Looking forward to the answers.
Best answer by TBelevska
