Hey @richard c! Daniel from Customer Support Engineering here 🔧
At the moment, it isn't possible to open up an article within the Messenger from a link. You can view articles within the Messenger with the Articles inserter app, or if a user clicks an article either from your Messenger or through the articles search app, though you can't show a specific article within the Messenger from a link outside of the Messenger. You can achieve this for Tooltips however with smart links.
If this is something that you'd like to see implemented in the future, make sure to drop it in our Product Wishlist Group 😊
Hope this helps 👋
Join the Intercom Community 🎉
Login to the community
