Hi there! Does anyone know if there is a way to disable the "Send us a message" option located at the bottom of a help center (picture attached) for mobile? It doesn't show up right away when users open the Help Center initially but after reading/opening an article and going back, it shows up. We want to disable this because this is bypassing the prevent multiple open inbound conversations option and letting users create new conversations despite them already having open conversations with our team.
Is there a way to disable the "Send us a message" option in our Help Center?
Best answer by Oseas
Hey @user2161! Oséas here from the Customer Support Specialist team 🕵️
By going to your Messenger settings, you can enable the option "Require search before starting a conversation" that will force users to search for an article before being able to start a conversation:However, if you have this option enabled along with "prevent multiple open inbound conversations" users/visitors should only be able to have one conversation open regardless of how many times they have opened an article in the Messenger. What the issue might be in this case is that you may not have these options enabled for both users and visitors in your Messenger settings, you can check it by toggling the following button👇
Join the Intercom Community 🎉
Login to the community
