In the knowledge base, we have a Glossary of Terms page. For some longer articles, I’d like to be able to pull specific terms and definitions from the Glossary of Terms page and display them in the second article. In this flow, if I needed to modify the wording of a definition, I would update it on the Glossary of Terms page, and that would flow into the second article, instead of having to update the definition in two+ articles. Is this possible?
