I've created a bunch of code blocks in my help article with carefully formatted whitespace. When I save the article the whitespace is stripped. I'm talking specifically about whitespace to the left of content.
This:
" some-command"
Becomes:
some-command
I had to quote the first example because the help center does the same snipping...
When I edit the article the whitespace is back! How can I keep it in place for viewers of the article?
Best answer by Aparna
