Hi, i saw in this article here that you should be able to see all edits made, check every version etc, but im not being able to click the versions or see the edits, is there a way i can solve this?
I saved a version and it didn´t actually saved and i can´t see the edits :/
Not being able to see Article´´´ s edit history
Best answer by Jennifer K
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
