I want to make sure some articles are only visible to users from specific countries. What properties can I use to make it happen?
Page 1 / 1
Hey
If you have audience targeting, you can select your articles to be visible to users from a specific country by adding an audience rule, as per the example below
I hope this helps!
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
