I tried ​contact support team of Intercom 3 times, but no reply yet.
Hey @user2119​ Racheal from the support engineer team here👋
I can see you're working with my teammate Cam, what this error means is that you've sent in the Quick Setup request too many times and now we need to reset your limit. As resets happen on a case by case basis, I'll leave you in Cam's hands as he will be the best equipped to help you out there!
