Why is my Custom Domain setup for my Intercom Help Center not working? | Community
  • September 13, 2020
  • 126 views
Custom Domain setup doesnt work, My domain is transferring to cutomer.intercom.help using cloudfront but intercom is not able to resolve to the article.
Thanks for sharing the domain URL, I look at this and record "help.qwary.com" does not exist.
You should double-check your settings or Try another tutorial. If this doesn't help directly contact AWS support.
Hope this helps.
Hey @manoj r11​ , Hope you are having a great Sunday.
To use a custom domain, you should create a CNAME record and point the domain to custom.intercom.help
Make sure that you entered your domain name in settings:
custom
If there still will be a problem, please share your help center URL and I will check.
Hi @roy s11​
Here is the custom domain : help.qwary.com
i have followed this document for aws route53 and cloudfront but it doesnt work.
https://developers.intercom.com/installing-intercom/docs/set-up-your-custom-domain/p>
Hope this helps.
  • January 26, 2021
At some point, setting the forwarding for cookies and query strings on Cloudfront became a legacy function, so for anyone looking for it as of this writing, in the Cache and origin request settings section you should set that to "Use legacy cache settings" in order to change those forwarding settings.
