Why is my Help Center custom domain not working? | Community
  • January 7, 2022
  • 8 replies
  • 424 views
I have setup CNAME details and everything correctly for showing Knowledge Base on my custom domain.
When I load the page, I see my logo in browser but page is white with text on 'Not found':
Why do I see this?
Best answer by Matt O12
I put now just your US server and it works.. not sure why you have then 2.. I put both but only EU one was accepted.
  • January 7, 2022
Hey @matt o12​, can you please share a screenshot of the CNAME record you've created for this domain? That will help us to diagnose this issue. Which provider did you use for this?
  • January 7, 2022
Screenshot 2022-01-07 at 19.21.13I used Cloudflare.. all same like in your insturctions
  • January 8, 2022
  • January 10, 2022
Hey @matt o12​, I can see that you've also been chatting with colleague Sean about this. As he outlined, your own Intercom workspace's data is stored is the US, which is why your CNAME record needed to point towards our US domain.
  • January 24, 2022
@eric f11​ I have the same issue. not matter if I put in US or EU. before that I had another value, which I can't remember (I used the new guide to set up SSL) and it worked. Now it does not work on any setting anymore. this is super urgent and the chat is telling me 2 business days. my Helpcenter is completely DOWN now
  • January 25, 2022
Hey @user2243​, can you please share a screenshot of your SSL configuration?
  • January 25, 2022
yes. sure. here you go. it started magically working again at some point, but now it does not work on https (shows as not secure)
I triple checked all tutorials intercom provides but can't find the fault.
I also can't revert it back to http somehow, then the above mentioned error occurs again.Screenshot 2022-01-25 at 13.33.18
  • January 28, 2022
Hey @user2243​, I can see that you're working with Evan in our Support team to get this resolved.
