Best answer by Kevin Bendixen
View originalWhy is our help centre showing as "Not Secure"?
@user444​ I assume you created a custom URL for your help centre, have you followed these steps: https://developers.intercom.com/installing-intercom/docs/set-up-your-custom-domain?showHidden=f2cb6#section-choose-to-configure-ssl-optional/p>
ah...perfect thank you!
Join the Intercom Community 🎉
Login to the community
Log in with SSOor
