Issue while presenting the help center view controller on iOS | Community
  • Mar 17, 2021 3:56 PM UTC
  • 316 views
Hello,
We are running Intercom 9.3.3 on iOS. We are trying to present the help center via the Intercom.presentHelpCenter() method, and the controller presented view controller is automatically presented then dismissed for an unknown reason.
In the logs, here is the message we can read and I don't really know if it's really linked to the issue:
2021-03-17 16:43:53.684162+0100 SKVideo[518:32150] [assertion] Error acquiring assertion: <Error Domain=RBSAssertionErrorDomain Code=3 "Target is not running or required target entitlement is missing" UserInfo={RBSAssertionAttribute=<RBSDomainAttribute| domain:"com.apple.webkit" name:"Background" sourceEnvironment:"(null)">, NSLocalizedFailureReason=Target is not running or required target entitlement is missing}>
2021-03-17 16:43:53.684395+0100 SKVideo[518:32150] [ProcessSuspension] 0x113705b50 - ProcessAssertion: Failed to acquire RBS Background assertion 'WebProcess Background Assertion' for process with PID 524, error: Error Domain=RBSAssertionErrorDomain Code=3 "Target is not running or required target entitlement is missing" UserInfo={RBSAssertionAttribute=<RBSDomainAttribute| domain:"com.apple.webkit" name:"Background" sourceEnvironment:"(null)">, NSLocalizedFailureReason=Target is not running or required target entitlement is missing}
Best answer by Ali K
Hello Eric,
Thank you, I just realized I was using the test environment and in this case, we did not have the help center active...
Thank you for you help of pointing me to the examples.
  • Mar 19, 2021 3:02 PM UTC
Hey @ali k​, could I ask you to try a similar call using one of our sample apps, please, and see if it works, or if you get a similar error message?
This will allow us to determine if the issue is in your Intercom workspace or in your iOS app.
  • Mar 19, 2021 3:33 PM UTC
Hello Eric,
  • Mar 19, 2021 3:41 PM UTC
Ah, great! I'm glad you were able to find the solution 😄
