I've set the Audience and it contains nearly 1,800 users. I set it live 5 days ago, yet no product tours have been delivered. Any thoughts?
Best answer by Magnus
View originalI've set the Audience and it contains nearly 1,800 users. I set it live 5 days ago, yet no product tours have been delivered. Any thoughts?
View originalHey @jake l11 👋
Would you mind sending us a message through the Messenger with these details attached so a member of the support team can look into this for you 🙌
Hi Lisa,
Thanks for the response- I tried opening up a conversation last week but wasn't about do get out of the "Bot" loop. Any tips for getting on with a person?
Hey @jake l11, Magnus from Support Engineering at Intercom jumping in here!
The reason for why a Product Tour does not send can be hard to determine without a more thorough investigation into your specific situation, but I thought I'd drop some general information as well as ideas of what it could be.
First of all, let's talk about Audience previews. When you set up your Product Tour (or any other content that is delivered in your app), you'll be able to target a specific subset of your users with Audience Rules. For example, you might set up rules like "Users AND Signed up less than 7 days ago" or similar. The Audience Preview will show you the users that match your audience rules and are eligible to see the tour, but they still need to come online and match any URL based rules that are set up in the "Where to send" triggers.
The "Where to send" rule will automatically be set to your Build URL, but you will likely want to change it. You can find these rules under the "Show your Tour automatically" section, under "Triggers".
These rules are used to ensure that users have navigated to the correct page where the Tour can be shown. Make sure the "Where to send" rules are:
I hope this might give you an idea of how the Audience preview differs from who actually sees your Tour, as well as how the "Where to send" rules work. Let me know if this helped you, or if you have any additional questions about this.
Hello :)
Big issue here
I cannot set a tour live
It stays as Draft and says :
Finish creating your tour
before setting it live.
And I did.
And it did not set live.
What can I do ?
What can we do ?
