I'm creating wallboard for my client where I have to show how many "total chat today"? How can I fetch that? Please help. | Community
  • April 27, 2021
  • 6 replies
  • 34 views
@anand​ , How about using Conversation Search API for that?
Sending request to https://api.intercom.io/conversations/search
 "query": {
  "operator": "AND",
  "value": [
    "field": "created_at",
    "operator": ">",
    "value": 1619481600
    "operator": "<",
    "value": 1619568000
1619481600, 1619568000 This Unix timestamps are for todays date.
  • April 27, 2021
Hello @anand​ , You are developing some custom solution or want to build some reports which will indicate total chats today?
  • April 27, 2021
Hi Roy, Thank for reply.
I'm developing a web app using NEXT JS where I can show some reports such as total chats, number of agents and Happiness score.
I'm using Axios.get method to fetch the data in next js - is this the right way of doing it ? Kindly suggest. Many thanks.
  • April 27, 2021
 "query": {
  "operator": "AND",
  "value": [
    "operator": ">",
    "value": 1619481600
    "operator": "<",
    "value": 1619568000
  • April 27, 2021
Thank you so much for your help !! 🙏
Can you please also help me to get the Happiness score as a percentage?
Many many thanks.
  • April 27, 2021
@anand​ Always happy to help 😎
About the Conversation rating, you should take a look at the following doc.
  • April 27, 2021
Thanks Roy,
can you tell me which API endpoint do I need for the Happiness score?
