Build failing with RN 0.74.5 and intercom 7.2.1
  • September 23, 2024
  • 193 views
I’m getting this errro:
Script '../node_modules/@react-native-community/cli-platform-android/native_module
s.gradle' line: 203 * What went wrong:
A problem occurred evaluating project ':app'.
> Could not find method implementation() for arguments [DefaultProjectDependency{identityPath=':intercom_intercom-react-native', configuration
='default'}] on object of type org.gradle.api.internal.artifacts.dsl.dependencies.DefaultDependencyHandler.
Hi @sadab ! Ebenezer here from Engineering Support👋.
That great, I’m glad its working now!!
This topic has been closed for comments
Shaq Payne
  • 27 replies
  • September 28, 2024
Hey Sadab! 👋
Thank you for reporting this issue! This error you're encountering suggests there's an issue with the way the Intercom library is being linked in your project. To resolve this, you should manually link the Intercom library if you're using React Native version 0.59. Here are the steps you should follow:
  • Add the Intercom library to your android/settings.gradle file with the following lines:
      include ':intercom-react-native'
      project(':intercom-react-native').projectDir = new File(rootProject.projectDir, '../node_modules/@intercom/intercom-react-native/android')
  • Then, in your android/app/build.gradle file, inside the dependencies block, add:
      dependencies {
          implementation project(':intercom-react-native')
    Make sure that you're adding these lines correctly and that there are no typos or syntax errors in your Gradle files. If you're using a React Native version below 0.65, be aware that there might be compatibility issues with OkHttp versions, as React Native versions below 0.65 use OkHttp 3, while the Intercom SDK uses OkHttp 4. To prevent compatibility issues, you should add an explicit dependency on okhttp-urlconnection in your app/build.gradle file:
      dependencies {
          implementation("com.squareup.okhttp3:okhttp-urlconnection:4.9.1")
    This should help you resolve the problem you're experiencing with the project evaluation error in Gradle.
More information can be found here: https://developers.intercom.com/installing-intercom/react-native/installation
If you still need assistance with this could you please write into us a Support@Intercom.io.
  • September 30, 2024
Hey @Shaq Payne
I’m using RN 0.69.12 and it’s working fine, the issue I’m facing is when I’m trying to update my RN version to 0.74.5
Also I’m not able to send the mail to
  • October 24, 2024
Apparently the issue was from our side, we decided to create the RN project from scratch and intercom works fine with it.
  • 188 replies
  • October 30, 2024
