integration between intercom and skype ? | Community
  • February 1, 2024
  • 158 views
How can I combine skype with intercom ?
Hi @Support 1 !
Intercom doesn’t have a natively built integration with Skype. Your best bet is to look around for a 3rd party integration that works for your team.
I just Googled “Intercom Skype integration” and came up with a few options. I would recommend doing the same, looking them over, and picking out the one that sounds best to you!
  • February 4, 2024
Hi @Support 1 !
  • February 5, 2024
Thanks for your reply Jacob
We try few of the 3rd solutions and all of them not working well
do you guys have any future plans to have this option  ?
  • March 3, 2024
Sorry for the delayed response @Support 1!
Currently we don’t have any plans to build our own native Skype integration. I can flag this with the team though so they are aware that their’s some interest in that.
