Intercom Images Synced To Zendesk Expire Within 1 Hour | Community
  • May 19, 2025
  • 61 views
Hi,
It appears that the Intercom CDN links synced to Zendesk via the ticket integration have a short expiration period of under an hour. After expiration it is not possible to view the images in Zendesk directly.
Is there a setting in Intercom to extend the expiration or is it possible to remove the expiration?
Best answer by Paul Byrne
Hey ​@Neil Ugerio Paul here from weekend support engineering.
Intercom’s CDN links are time-limited (usually under 1 hour) for security reasons, and there’s currently no way to extend or disable the expiration.
If you need long-term access in Zendesk, you’ll need to download the files before they expire or use the Intercom API to fetch them securely as needed.
Happy to flag this as a feature request if it would be helpful!
Paul Byrne
  • May 25, 2025
  • May 26, 2025
Hi ​@Paul Byrne thank you for the information. It’s very helpful!
Paul Byrne
  • May 26, 2025
Hey ​@Neil Ugerio that's what I love to hear :)
