Intercom - Linear Integration. Search for linking an existing issue or project is not working | Community
  • September 2, 2025
  • 446 views
Hi everyone! Is there anyone here using the Linear integration? We just added it and the search option to find and link a conversation to an existing issue or project is not working. It’s not showing relevant results.
Best answer by Joseph S.
Hi Kath,
A couple of quick things you can check to help:
  • The search in the Linear app inside Intercom is pretty strict: it only looks at issue titles and IDs, not the full description. If your keywords don’t match exactly, it’ll look like nothing’s there.
  • Make sure the Linear workspace is connected to the same team/project you’re trying to pull issues from. If you’re in a different workspace or project, results won’t show.
  • Sometimes re-authenticating the Linear app in Intercom refreshes the link and fixes stale search indexing.
If it’s still empty after that, it’s worth dropping Intercom support a note because they can check the API call logs on the backend.
Joseph S.
Forum|alt.badge.img+6
  • Expert User ✨
  • September 2, 2025
Hi Kath,
