Hi everybody, we are integrating Intercom with two of our custom built applications. In these two applications we have built the standard integration with Intercom. When I sent a banner or chat from Intercom to these applications, they only appear within these applications when I do a refresh. Of course this is not the behaviour that we want: we want our users to directly see the banner/chat in the applications. Both applications a web based cloud native. It seems that the push mechanisme does not work. What are we doing wrong?
Push and integration with Intercom
Best answer by Nathan Sudds
It’s possible this maay be to do with a conflict with your application and Intercom’s widget as well, I would recommend opening up the Developer Console if you can do this in the webapp version and see if any errors popup there as well.
Hope this helps you get some more answers to your issue here.
Join the Intercom Community 🎉
Login to the community
