AWS Cloudfront best practices | Community
  • May 17, 2022
  • 479 views
Hi,
I created a cloudfront distribution that pointed to intercom.help for our company and that works fine, it's all set up with no issues. The problem arises when i went to review AWS Security Hub to review best practices and I noticed a critical issue. The title of the best practice is "CloudFront distributions should have a default root object configured". I reviewed the guide to set up a cloudfront distribution from Intercom and it has no mention of setting a root object. I wonder if anyone else has run into this and solved it?
I've tried a few potential root objects like /en since that's what it redirects to if i got to intercom.help/company but everything i've tried to add it just redirects to a 404 page.
Thanks
Best answer by Lisa B11
Hey @eoin m​ 👋
Have you had a look at this article from CloudFront side https://github.com/matt-alex-wong/Intercom-SSL-Setup-Guide/blob/main/README.md. and this https://medium.com/@getsee/make-your-intercom-help-center-https-with-a-custom-domain-2255cba66f50 those may help you out 🙌
If not, would you mind sending us a message through the Messenger with a screenshot of your settings and share with us where the issue is happening, our support team can look into this for you in more detail.
  • May 19, 2022
Hey @eoin m​ 👋
  • August 15, 2022
I ran into this as well. I had to set the "Default root object" to just a forward slash to get it to work correctly and resolve the Security Hub alert.
