Can I add gifs to my articles? If yes how to do so? | Community
  • June 24, 2022
  • 705 views
how to add gifs in articles
Best answer by Kevin Bendixen
@rajesh d​ A GIF is basically an image format. So it's the same as adding a picture.
Kevin Bendixen
