Embed Vimeo | Community
Embed Vimeo
  • May 9, 2023
  • 456 views
How do I embed Vimeo videos to tooltips? I have tried embedding the video as well as downloading the video and uploading it as a video clip?
Best answer by Nathan Sudds
@Carmen McGrady Can you share the video link you are trying to embed, maybe we can test to troubleshoot for you -- it could be that the privacy settings of the video won’t allow embedding?  I believe unlisted videos can be embedded, with just the URL but not sure.  Private videos may not be able to be embedded.
I just tested with a random Vimeo video (The AI created beer commercial actually) and it worked correctly, but it’s a publicly available video -- see here:
Here’s the link if you want to try embedding it to see if it works for you:
https://vimeo.com/821962936
Milan
  • May 10, 2023
Hi @Carmen McGrady
When editing the tooltip content you have the this + sing where you can choose to either add video (choose one from your computer) or embed it (from youtube, vimeo, etc)
Does that work for you?
  • May 10, 2023
Hi Milan. Yes, I have both options but neither worked for me.
Forum|alt.badge.img+8
  • May 11, 2023
