How can I update Articles quicker? | Community
I need to link on the bottom of each article pages to related articles. At the moment i need to add the links manually which makes a lot of work if i need to add or change something
Hey @user1862​ Racheal from the support engineer team here👋🏼
While there is no out of the box way to bulk update Articles, you may be able to do this a bit quicker using our Articles API. Check out our dev docs, as well as this Article!
