How can we get more detailed feedback on our articles? | Community
  • February 2, 2021
  • 39 views
Is there a way to ask customer's feedback on articles, except thumbs up/down? Ideally, if they didn't like it, customers should be able to give feedback if they didn't like the content or the way it was written.
Best answer by Kevin Bendixen
@knowledge​ If you enable the option from the screenshot your users can do exactly that. It will then show up in your inbox.Bildschirmfoto 2021-02-02 um 13.18.29
Kevin Bendixen
  • February 2, 2021
