How can you make links stay in the same window from Articles? | Community
  • September 21, 2022
  • 447 views
Can you make links open in same window within articles, instead of forcing them to open in a new tab? (they all get generated with target=”_blank)
Best answer by Racheal
Hey @evan c​ Racheal from the support engineer team here 👋
Links that are on the same domain will stay in the same window, if the link leads to a different domain it will always open up in a new window. You can test this in our Help Center by clicking the links under What’s next? at the very bottom of this article to see how we've set that up 👇
https://www.intercom.com/help/en/articles/4792459-link-directly-to-headings-within-help-articles/p>
I'll happily flag this as a feature request for the team to consider!
  • September 23, 2022
I believe the request should be the ability to toggle any link's treatment, on whether it opens in new tab vs same window vs new window. I can see use cases for each. Thank you!
  • January 7, 2025
I’ve submitted this as an IDEA:
Please UPVOTE if you’d like to see this functionality.
